Gears of War: Reloaded
6 posts in this topic
Bu çıkmış sanırım dün, bana da bedava Redeem etmek için Xbox uygulaması üzerinden kod gönderilmiş ancak yeni farkettim. Gears of War Ultimate sahibi olanların hepsine gönderildi diye düşünüyorum. PC Game Pass için de yüklenebilir durumda.
Bloody likes this
Share this post
Link to post
Share on other sites
Vay be, PS5 Pro enhanced olarak Playstation Store'a da gelmis...
Digital Foundry incelemesinden;
- Re-imagining of the 2015 Ultimate Engine with a slew of improvements.
- Still running on UE3 with custom and hybrid effects not found in the Ultimate release.
- Improvement in settings like Reflections, modern-upscaling solutions benefits all versions (incl. PC)
- PS5 doesn't really have official support for UE3 so Coalition had to work off of unofficial UE3 code on PS4
- Native HDR rendering also supported on all platforms.
- Higher quality texture compression, baked GI and fidelity with crisp well-defined results.
- SSAO upgraded to AMD's CACAO. Additionally it has sharper baked and dynamic shadows.
- Shading and lighting refined across the board eliminating many artifacts
- Though the overall picture 'largely looks the same' with cleaner results
- Cut-scenes are still pre-rendered video clips but they're all re-rendered with internal 8K resolution downsampled
- However they're still encoded at 30fps. DF asked Coalition who clarified it would have required significant code re-writes to re-render them at 60.
- DF thinks some elements from the original 2006 X360 release like the raindrops feel less impactful in all future releases, same for krill storms
- Other minor nitpicks but overall visual presentation is solid and holds up in 2025
Resolution metrics:
- All consoles offer 60fps and 120hz unlocked options (seems to be for SP as well ???)
- SX and PS5: 1440p using FSR3.1.3 to up-scale to 2160p - Changing to 120hz drops to 1080p on both.
- Series S: 1080p up-scaled to 1440p at 60fps - 120hz drops to 720p
- PS5 Pro: 1620p up-scaled to 2160p at 60fps - 1440p in 120hz
- PS5 Pro switches to PSSR instead of FSR3.1 and provides a better resolve than FSR
- All console versions look sharp and provide a good output, even Series S
- PC has native ultra-wide support though it causes perspective to shift 'up' a little bit
Performance:
- Edge cases are always possible, DF did not find any drop from 60fps in any of the console versions 60fps modes
- 120hz ranges from 70 to 120fps on all machines, with none of them giving a locked 120hz at all times
- PS5 Pro out-performs the base PS5 in pretty much all cases
- Series X outperforms PS5 in 120hz with both running the same metrics
- But currently, VRR does not work properly on the SX version which DF thinks is a bug, though it works fine on PS5
- DF suggests using the 60fps cap on Xbox in the meantime
- DF also tested the "Energy Saving" mode * on PS5 which locks the game at 30fps or 60fps with lower fidelity
* This is an optional system level setting on PS5 to reduce energy usage. Theorized as something to test output on a potential PS handheld later.
PC corner:
- Average CPU utilization improved over the Ultimate version leading to much better performance
- The game is also shipping with "Rog Ally" approved settings
Edited by JardeL
Share this post
Link to post
Bu da olmamış maalesef, HDR çok kötü, kullanılan DLSS versiyonu çok eski ve oyun Xbox olduğu için Xbox oyun klasörleri şifrelenmiş oluyor, hiçbir şey değiştirilemiyor bu yüzden, Nvidia App da işe yaramıyor, bari 240 FPS limit ayarlanabiliyor, sonuç olarak olmamış bu da. Bu tip şeyleri ya düzgün yapmak ya da hiç yapmamak lazım.
Share this post
Link to post
HDR 1000 kandela yapınca bir miktar topladı, bu şekilde bitireceğim artık. Ancak orijinal oyunun SDR olarak kontrast ayarı kesinlikle bundan iyiydi.
Share this post
Link to post
PS5'e alıp nostalji yapayım dedim de, raflara bakınca unuttuğum PC kutulu sürümünü gördüm. PC'ye ilk çıktığında yıllar önce almıştım. Aklımdan çıkmış. Masraf yapmaya üşendim bendeki kutulu oyunu kurar tekrar oynarım bir ara.
Share this post
Link to post
iyi de bu remastered versiyon, orjinali değil :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
